2.26 app RC, v2/Pan, v3, Sense Hub, Bulb v1, Wired Doorbell, Cam Outdoor & Base Station Firmware Beta Test - 11/3/2021
Had the same issue with a previous Wyze Doorbell where it would error out after scanning the qr code. “QR code incorrect” nothing fixed it, had to replace it.
Mine doesn’t get to scanning the QR code. It’s hung at ready to connect.
Agreed. Please let us disable the banner somewhere in settings.
Mine is actually connected to my network. Everything is working except being able to connect via the app.
I get events but no notifications and the event won’t play. VoIP calling works when doorbell is pressed, and Alexa now announces when the doorbell is pressed. I also see it in my router as connected. I simply cannot connect and the light flashes blue.
Working with Wyze to see if they can OTA push the prod FW.
That’s exactly were mine was before deleting the VDB. Now it just won’t connect.
I just have run into the same issue you are having. Updated to newest firmware, VDB shows on my network but it won’t connect in the app. I submitted log 344290 but have yet to contact support.
Same here… Sense Hub update failed. Hub is bricked and in a bootloop. Won’t reset. Not happy. :unamused:
I updated 3 v3’s, 1 v2, 6 bulbs v1, and a doorbell. All good, the only thing is I had to reboot 1 of the v3’s. I updated them mostly one at a time, although I did a couple of the bulbs together and a couple of the v3’s together. Now if we can get rid of the banner, please.
Finally got mine back. What a pain. Had to delete the device from the app. Press (not hold) the button on the back to get, “Ready to connect”. Went thru the process to add a new device. But, it was not working with Home Monitoring. After messing around for a while, I eventually was prompted to set up HMS like I did the first time. In hindsight, I think force closing the app, after adding the Sense Hub, may have brought this prompt sooner. Again…real pain in the……
Also, after adding the hub, all the sensors and keypad have to be added again. The keypad showed offline each time. Taking a battery out, then putting it back in, got it back online.
Spent about 3 hours with all of this. Adding all the sensors…recreating all the rules associated with them……
Ugh!
Just got mine back a minute ago. :+1: I held the reset button down for 60 seconds while plugged into power and Ethernet, waited for a boot cycle (3 lights cycling), waited for only the right light to remain lit, then tapped the reset button. Added hub and everything back to normal with no loss. Going to try to reapply the firmware update now, this time while connected via Ethernet. Previous attempt was via WiFi.
You should never have to delete your hub unless you are truly removing HMS to perform a complete HMS factory reset. Any time you tap the reset button and hear, “Ready to connect”, just add the hub from the app Home page even though a hub is present in your devices list. Your sensors and all settings will be re-associated to your hub and the app will not create a duplicate hub in your list.
Update: Strange… Hub is already running latest 4.32.7.150 beta firmware. :thinking:
“Should never have to” ….key words there. I tried what you did. The hub came back online, and sensors were connected in the app. However, the sensors were not triggering anything, and, the hub was not working with HMS.
Issue navigating (swiping) Events in Android beta app 2.26.16:
My hub was also wireless when installing the update. Won’t connect wirelessly, now. Wonder if being wireless caused the issue…
Mine was wireless also
Does anybody’s Sense Hub work wirelessly, after this update?
That didn’t work for mine
Updated from bulk page, and it was connected wirelessly
So was mine. It won’t connect wirelessly, now. Does yours?
Mine won’t connect wirelessly. Still trying different things, but not in the mood to do a master reset… way too many devices tied to HMS.
I am getting the same issue as others reported when updating my Wyze Sense Hub firmware to this latest version. The device no longer connects and I hear a faint crackling sound from the device I did not hear before
