You will not receive these notifications until you enable person detection
“you will not receive these notifications until you enable person detection under smart detection”
Hi all,
I did that, but still get this message.
I had this V3 in a different location, brought it home, deleted the device, re-created it, re-enrolled in Lite, but it won’t do any notifications.
It’s at 4.36.9.139.
Any ideas? Is there anything else I can try?
Thanks.
I’m seeing this as well, I think it’s just a visual bug. As long as your getting the notifications you want, you can safely ignore it for now
Thanks IEatBeans, but the problem is I’m not getting any notifications, like the message says.
Are you seeing the same message but you’re getting notifications?
My other two cams don’t have this problem.
Thanks.
Oops, sorry, missed you saying you aren’t getting notifications. I am getting notifications even with that message.
Well, I guess the only remaining option is to delete the device again, re-create it, re-subscribe to Lite, and only then select the various options.
I think I didn’t follow that sequence before.
Thanks again.
On edit, I found some other threads that mention notifications have stopped, or are intermittent. I guess I fall into that same situation.
The only why I’ve been able to get notifications is by having “Detects Any Other Motion” selected. Which is super dumb, considering the camera having this issue has a Plus subscription. What am I even paying for?!? :grimacing:
