On android, Go to ,Settings , notifications , ,scroll down and Then tap wyze, tap wyze normal, tap sound , find and Select the Sound You want for Wyze notifications
What version of Android are you running. I am on Android 8.0 and what you describe is not there.
Notifications is a different menu than you have.
I am running Android 8.0 , on samsung s9+
There are different ways to get to it.
Try, Settings , apps ,scroll down and Then tap wyze, tap notifications, tap wyze normal, tap sound , find the Sound You want .
Or , Settings , notifications , advanced, scroll down and Then tap wyze, tap wyze normal, tap sound , find the Sound You want .
No such settings on my Sony Xperia XA1 Ultra with 8.0
I can’t find anything that allows for different sounds for different apps. No “Wyze, Normal, Sound” anywhere.
I am not a noob either, I know my way around Android since Éclair.
Hmm, I guess maybe it’s a Samsung feature , works on my s7 also
Yes, it is a Samsung-specific feature. They modify stock Android fairly heavily and have their own launcher, all part of the Samsung experience. I generally don’t like the Samsung Android experience but in this case it’s a nice feature they’ve added.
For stock Android you can use an app like NotifiCon or Megasound to set app-specific notification sounds.
