After weeks weeks of normal operation after installing the sensor bridge, now the cam is frequently going down (offline, yellow light). All other cameras normal. To recover, unplug then plug back in. But this only works temporarily. Something’s different. Does my Pan need to be replaced?
@acs Welcome to the community. Sorry to hear you are have problems with your cam and bridge. Currently there have been several issues using the bridge in a pan cam. It is recommended to use the bridge in a v2 cam until they come up with a fix. It isn’t in every case, but it sounds like you are experiencing the same thing many others have reported with their bridge and pan cam not working. If you can try using the bridge in a v2 cam this might be a solution to your current problem.
