Need some incite on what is going on with my bridge. I have it connected to a WYZE pan cam and it seems to disconnect from sensors 75% of the time when moving the camera. I’ve done the restart via android app. Light was still in a solid yellow. Have had to do a power cycle by unplugging and plugging it back in and removing the bridge and then reattach the bridge once camera is up and running. It’s getting very frustrating because that cam needs be able to pan scan the room that I have it in. Need some help please.
Had that happen to me with my cam pan also.
Seems that the add movement by panning causes a current drain that the Bridge is dependent on.
So I also tried a 2.4 amp USB brick also a shorter USB cable with no avail.
Ended up moving the Bridge to a V2 and all seems to be good for now.
Sorry to say … for me anyway that Cam Pan seems not to be 100% compatible with the Wyze sense system …
It should just work like it is advertised …
Wyze R&D is to be to blamed …
