Cam suggests power cycle. No effect.
Cam rotates 360, waits about 60 sec and rotates again continuously.
Tried holding setup button until voice prompt. No effect.
Removed SD card and retried setup. No effect.
Help!
Help!
Can you try moving camera closer to router?
Moved cam to 10 feet from router. No effect.
In that case, you should file a support ticket, preferably from within the app just after experiencing the issue so Wyze can collect and examine the logs.
Having the same issue ![]()
Hello @julie_carolelebel, are you experiencing an “error code 90” when trying to view the cameras live stream?
Just found the problem, my phone needed an update and the internet shows a 6.4% packet loss in the connection.
