In my “update” for watch shipping it said:
“In the meantime, do you have your Shortcuts set up to control your other Wyze products?
Could be a good distraction to set them up ahead of getting your watch so you’re ready to integrate when you set it up.”
I have no idea what that means. Help!
Click the plus sign in app at the top left, choose add rule, then select shortcuts. ![]()
It seems to me you need the device added to create a shortcut.
The device isn’t required.
Take a look at the section of the article @Omgitstony linked.
What are Shortcuts?
Shortcuts are actions controlled by tapping an icon from the Home screen of the Wyze app.
Example: Turn off all Wyze Bulbs with a single tap before going to bed.To create a Shortcut:
- Tap Home , then the + plus sign on the top left.
- Tap Add Rule , then select Shortcut from the list.
- Add a name for the shortcut in the text box under the star icon.
- Tap the star icon to change it to a different icon.
- Tap the + plus sign next to Action .
- Select the actions you want to trigger when you tap the shortcut.
- You must add at least one action to create a shortcut.
- There is no limit to how many actions you can add to a shortcut.
- To save the action, tap Save .
- To add another action tap the + plus sign next to Action again.
- When finished, tap Save .
All I see when I do that is control of cameras. Maybe I’m spoiled by Amazon and Google. I was expecting something more - turn on the shower, start breakfast, get out clothes for today. ![]()
