Wyze watch 47 Battery charge
How often should I charge the battery on my Wyze Watch 47?
Hello @lharrisonlee2 and welcome to the community.
I charge mine about every 3 or 4 days, but it could go much longer. It is usually around 50-60 when I put it on the charger.
I’m on day 10 and still have 27% left. That’s with daily wear and syncing text messages, calendar events, and cellphone call notifications to the watch. I’d say to just watch your charge status and figure out what works best for you. I’ll probably recharge at around 20% unless I plan to be away from electrical service for a few days and then I’ll make sure I have a full charge before that happens.
Where do you see the percent of charge used?
Let me say right up front that I’m retired and I don’t put my watch on every day. It still gets my texts and buzzes when I get a phone call even if I’m not actually wearing it. I just went 4 weeks without charging it. The only reason I charged it was because it had 15% battery and in order to update the firmware, it required a minimum of 20% charge. Pretty awesome watch!
My 47 lasts about 9 days for my use, which is mainly raise-to-wake and notifications. Find out how long yours lasts for your particular use, and set a reminder to recharge it before it dies.
You can see how much charge remains by ‘paging down’ from the clock face. If the percentage hits the teens, recharge it!
On my Watch 47 you see the percentage of charge remaining by swiping UP from the bottom of the main screen.
As a related question, when does the community most often charge their watch?
So far I have used a long drive on two occasions as a time to charge my 47. I suppose anytime I have deskwork seems appropriate as well, but I won’t get my stretch reminders in those instances :sunglasses:
When do you charge?
Thank you.
