WYZE Video Doorbell v2 door bell chime controller
I’m replacing my Video Doorbell V1 with Video Doorbell V2. The old one had a connector that spliced the wires together at the old doorbell chime…and separate wall outlet plug in bluetooth chimes for front and side doorbell cams. The V2 Video Doorbell has a chime controller that gets wired in and works with an existing doorbell chime. I want to install the V2 at both the front and side doors.
Question… Will a chime controller function with two V2 Video Doorbells? How to…?
No. You need a separate controller for each doorbell. v2’s will each come with a controller, while you will need to purchase controllers separately for the duo if you upgrade to that level.
