Has anyone tried to have 2 cameras on one doorbell chime?
I personally have separate wiring and separate chimes for each, however, I don’t see any reason why you couldn’t use the same mechanical chime. You could either split the wiring, or you could use the rear wire for one in back.
Might be even easier if you have a digital chime so there is less wiring to worry about.
No, one Wyze Chime can only connect to one doorbell at this time. You can get extra chimes for your doorbell or explore using smart speakers as chimes.
