Please change App to allow joining 2 or more Wyze Chimes with a single Wyze Video Doorbell to allow Wyze Chime-ing in two different rooms (or upstairs/downstairs) when Doorbell is pushed. This is not a hardwired chime that comes with a normal doorbell, but the Wyze Chime unit that comes with the Wyze Video Doorbell.
I first need to make sure we are discussing the correct doorbell.
The Video Doorbell V1, hardwire powered:
This doorbell CAN have multiple chimes installed as accessories to the doorbell. Wyze recommends no more than 4 to reduce the possibility of latency. These chimes are installed thru the Cam Settings page for the VDBv1 and selecting Accessories and then the + plus sign in the upper right.
The doorbell chimes can be purchased individually from Wyze.
The Wyze Video Doorbell Pro, battery operated or hardwire powered:
This Chime “Pro” is actually a WiFi Bridge for the Doorbell Pro. The Doorbell Pro doesn’t connect to your WiFi, the Chime does. The doorbell connects to the Chime. Because of this, pairing of the doorbell to its Chime as a bridge is imperative. It will not operate without it. Because the Doorbell Pro can’t be connected to more than one WiFi source, it is limited to only one chime.
My only chime doesn’t work, there isn’t solid blue light, only solid yellow light. What is the solution?
So the wyze video doorbell pro can be set up that when the button is pressed other actions can be initiated.
Examples: sending a notification to your phone, triggering a voice announcement, launching a live view of the camera, and even initiating a VoIP call. You can also create automations to control other Wyze devices, like turning on porch lights or activating other cameras when the doorbell is pressed
But they can’t have it set up for when a second chime is added to the wyze echo system will chime when button is pressed?
Not a second Chime Pro, no, but last year they introduced Duo Cam Doorbell with Wi-Fi Chime, and earlier this year they began selling the accessory as Universal Wi-Fi Chime. As far as I know, Wi-Fi Chime would be the only way (currently) to add a second (or third, or fourth…) chime to an existing Video Doorbell Pro.
