Wyze Video Doorbell, At 90 Degrees, Not Facing Street Questions
HI All,
I would like to add the Wyze Video doorbell, wired version to my home.
Problem is, my wires are on the wall next to the door, 90 degrees away from facing the street/walkway.
Is the angle wide enough to capture?
Is there a wedge to add view range? The wedge I saw changes the vertical view, not the horizontal.
I am not able to find any other sources on YouTube to help me make my decision.
Pics or video would be great!
Thanks!
Here are a few options from Etsy. However, the V1 Doorbell provides a few angles you could use as well:
or
or
Thank you so much!
You have helped cement my decision!
Remember, this is for the v1 doorbell not the v2. I am sure they will or do have similar ones for the v2 doorbell
V1 as in the wired type, yes?
Yea. The v2 is battery, but you can also hook it up via the Wires as well. provides both optiopns. One difference is the v2 is a fish eye so you can see more, the v1 has no fish eye. I have the v1 and like it a lot. the v2 also supports 5G
Here’s a question I hope you can help me with :slightly_frowning_face:. I need to change v1 doorbell’s angle of view from the default 45° to 90°. If I buy another 45° wedge from Etsy, will it snap onto existing 45° wedge for a total of 90°s?
