We have the Wyze Doorbell camera and we have to mount it perpendicular to the door. This is to suggest the the top half of the unit be put on a swivel so the camera can be turned toward the street when mounted on the perpendicular.
Like a this:
Or a this:
do you have photo examples?
im still working on a design. im going to fabricate on so that its adjustable on the x and y axis for side to side and up and down.
very tight measurements through…it’s going to put my welding and cutting skills to the test
What I would like is if the camera half of the doorbell could twist 90 degrees left or right. This would eliminate the need for a swivel mount.
