Wyze doorbell wedge with more angle
Would be nice to have another wedge with more angle. In my case the old doorbell was mounted at an awkward spot and facing the other wall. The existing wedge gave me a little angle but would love for it to face more straight ahead of the entrance.
Mod Note: Title Edited to Enhance Search Clarity.
Don’t forget to vote for your own #wishlist item!
I have seen a few people get creative and use poly door shims and some glue to make a new shim :slight_smile: more to their angle of need. it’s an idea
Perhaps model one up with tinkercad and someone could 3d print it? What angle are you looking for? Mine hasn’t shown up yet, so I don’t know the exact dimensions of the base.
Well they say the included wedge is 30° angle, and as you see on the picture above my door is to the left. Maybe a 45°+ angle would be much better and capture more ahead.
Of course, my entrance is different than yours. I think that a 15 degree wedge would be perfect for me. I agree that there should be more wedge options.
Yes! :grin: Relocating in some cases would be a pain. That would solve the issue.
My angle of view is about the same as yours, Phubu 'cuz it’s mounted on wall perpendicular to door. Need 90° wedge. In the mean time, I get a nice view of the neighbor’s driveway.
Still makes more sense in your case, i have a wall :joy:
I installed my with the included 30 degree wedge (right Image) and it was ok, but not ideal.
i found a 45 degree wedge on Etsy (left image) and it much better. The seller said 45 degrees was a steep as he could go to still accommodate access to the screws but I think it could have gone even steeper with a little tweaking but overall I am very happy with the 45 degree wedge.
See that’s much better👍
Looking for a better doorbell wedge that allows for a view of my front port home. I have a blind spot of anyone standing on the opposite site of the doorbell closer to the house from the position it’s in. I flat mounted it too but was even worse .
Need a 55 or 60 degree horizontal mounting wedge for the WYZE video doorbell.
I found this adjustable one on Amazon: https://www.amazon.com/dp/B09HGN88BC?psc=1&smid=A3L9663CMWRIQ2&ref_=chk_typ_imgToDp
There are 3D Printed ones on Etsy with an even bigger angle, but the shipping on them makes them overpriced
2 posts were merged into an existing topic: Horizontal Wedge for Video Doorbell Pro
