WYZE V3 Cam Beta Version 4.36.2.5 update
WYZE cam v3 update 4.36.2.5 just finished updating - anyone know the changelog?
Mixed bag with this one. Remote site one upgraded and the other camera won’t even after a software reboot. Local site one upgraded and the other two refuse to even after physical power cycles.
I think the beta Notification may have the wrong version listed. This is the announcement:
Nope. 4.36.2.5 is out for the V3 cameras. Updating six now.
Thats what I was saying. I updated 5 V3’s to the 4.36.2.5 version. but the Beta notification I linked said it was 4.36.2.1. I think the notification topic incorrectly listed the version as .1 and not .5. Otherwise, what is the difference between .1 and .5.
As an FYI: After loading the firmware I had to clear cache and reset my camera’s as they were all going to 0 Kbps and one showed off-line. after cycling them, they connected.
I must have a peculiar configuration on mine with only about a 40% success rate. I will probably have to factory reset or just wait for next firmware. It’s been a while since I had a failure rate this high. Good to hear others aren’t seeing issues.
The FW loaded fine. The execution or streaming is where I had my issues. At times, I have noticed that when a FW fails to update, doing the simple clear Cache, shutting the app down, rebooting the phone and trying again worked for me. But this is not a frequent experience.
Things seem to be loading for me after a rocky start. :slight_smile: Hope you get your worked out.
Finally got all but one updated. The last one at remote location finally went offline during an update attempt. I’ll have to fix in a week or so.
Anyone find the change log?
Yes, in the third post.
The one that went offline appears to be bricked. Just solid red light with no ability to reflash to older version. Good thing under warranty. I’ll open a case with Wyze tomorrow.
I opened a case today. This is the first one that has ever been bricked. I’ve never even needed to revert back to an earlier firmware. Only failure I’ve experienced was a V2 where imager became faulty. I’m running 39 cameras (mix of V2/V3/Pan & WCO)
Does resetting your camera mean adding it again? I’m experiencing a similar issue, power cycle didn’t work in my case, and I’m still not able to readd mine because of the location unmounting it is inconvenient.
No, I first try a restart on the camera, if that fails the. I pull the power and leave it unplugged for a out 1 minute or more. Normally that is enough for it to work. The biggest habit I got into is clearing cache from within the app. In addition, if you have Android, I would clear the cache by longest pressing the app icon and going to app info.
Thanks, I was able to get it back up and running. Although I had to go complete the process of adding a new camera for it to reestablish the connection.
