Is it possible to set a static ip in a V2 camera. Am in Fl and we’re prone to outages now and then. When it happens, I always have to go into my Synology surveillance to reset the ip. Is there a way to set a static ip. TIA
you would normally do that via the Router. In the router you would set an IP Reservation for a Mac Address. Then every time that device connects, the same IP will be provided to the camera or any other device.
What type of Router are you using?
