cameras quit working after cox upgrade
Did your wifi network logins change? Did you have to re-log your phone or tablet into the new wifi? You’ll have to do that with each device or the easy mode is to just change the new cox equipment wifi information to the exact same as the old info and everything should connect. Some devices might need a power cycle though.
Thx, deleting devices and reinstalling seems to have worked!
If the future, no need to delete them. Just reinstall as they would retain your previous settings. :). Glad it’s working!
