I have been searching online since I have places the Wyze Thermostat in service at one of my business locations… .Have had issues with connectivity but that is a separate issue. The low temp band only goes to 50 degrees - noticed most if not all go between the 40-50 degree band on the lowest temp setting - why not be different and unique and bring the band down to 33 degrees - This location I need the temp to be adjustable just above freezing 50 degrees is way too warm and adds added cost with both gas and electric utility cost - Having tis lower band range perhaps through a firmware upgrade would add great value to the product.
Related topics
Topic | Replies | Views | Activity | |
Reduce the minimum temp on Wyze thermostat from 10'C to 6'C | 1 | 306 | December 1, 2023 | |
Wyze thermostat lower temp limits? | 4 | 618 | January 8, 2021 | |
Thermostat settings | 4 | 459 | October 6, 2020 | |
Why is my thermostat not adjusting to the temperature inset it to? | 4 | 36 | December 10, 2024 | |
Thermostat temperature range | 17 | 3044 | February 1, 2023 |
