I know there was/is an issue with the thermostat showing up as offline, I luckily never got that issue eventhough I’m using a Pixel 10a running the latest Android 17. The issue I’m having is with my schedule not running, I have three thermostats and all three I have set a new scheduled and non are running correctly. I have tried deleting the schedule blocks and recreating, I have restarted all of the devices via the app and manually and still nothing. Not sure if this issue can be tied to offline issue but wanted to see if anyone else is having the same problem. Thanks!
I was away from my Condo for 8 days and set my Thermostat to OFF with no Hold.
- I have been away many times before with these settings and no issues.
- However, this time the Thermostat kept going OFFLINE and coming back ONLINE after a few hours. This happened multiple times. Internet was working as my OG camera was working.
- I asked my Superintendent to turn the furnace breaker OFF/ON but the OFFLINE/ONLINE continued.
- When I returned on Mon Oct 19, the Thermostat was ONLINE:
- I power cycled by pulling it off the wall and plugging it back in.
- Switched to Cooling expecting the simple Home at 8am and Sleep at 11pm Schedules to resume.
- The Thermostat remained ONLINE but the Schedules didn’t work.
I tried solutions posted in other Topics:
- Factory Reset and set up again didn’t fix schedules.
- Not a time or time zone issue:
- Setting Hold until a specified date/time works.
- Schedule didn’t change over 24 hours.
I bought the Thermostat in Jan 2024 so it’s only 22 months old and warranty has expired!
Time to look for a replacement.
Interesting! I too had turned all three thermostats off as the weather was nice out for a while. Maybe that’s were the problem lies? Hoping someone from Wyze has an answer or maybe I may have to do a reset. Thanks for your reply!
Sorry you’re dealing with this on three thermostats at once. One thing worth checking, since you’d turned them off for the nice weather: as far as I know schedules only run while the thermostat is in Heat, Cool, or Auto, so set each one back to a mode (and make sure no Hold is active) before judging the schedule. It might also help to check that each schedule has the right days ticked and that the thermostat’s location and time zone in its settings match where you actually are. If it still ignores the schedule after that, I’d send logs from the app so Wyze can see it, since TerryL’s thermostat is acting the same way.
Same as well. I did have the offline issue but everything was working so I never did anything about it. I figured it would sort itself out. But not long after that as the weather was changing I switched from AC to heat and ever since then the schedule has been non functional. Sometimes it switches from sleep to home or vice versa but sometimes not and the temperature settings are completely wrong. The set temps and the temps set in the schedule are all correct but then it never follows them and just picks random numbers to be. I have a toddler in the house so having the heat decide it wants to be at 60 isn’t ideal…
Thanks for the reply! I have two set on auto and one set to heat and even that doesn’t do the trick. I like @ccwatson160 be getting random values for my temps eventhough I have set everything on the temperature preference and the schedule. I did do a reset on one of the three and nothing. All of my location setting are as they should be as well.
Hello, I am having the same issue. The thermostat does not follow its schedule anymore. I can control the temperature setting manually but it completely ignores any schedule i have set. I completely reset the thermostat and set it up all over again and reprogrammed the whole schedule which was a huge pain but it still didn’t fix the problem. I also made sure the app was updated to the latest version.
Wyze what is going on?!? This isn’t just a camera, this is the thermostat which controls the temperature inside my entire house. This is way more serious than any of my cameras not working. Please fix this issue immediately!
For reference I have a Pixel 9 pro running android 17
Hi @WyzeJasonJ
As winter is setting in, more people are reporting this issue.
Please raise with support.
Hi @WyzeJasonJ
Here’s another topic on the Thermostat scheduling issue
My thermostat has stopped following the schedule. I’ve tried everything including rebooting the router, cutting power to the thermostat, and restoring factory defaults and reinstalling the thermostat. It worked for the last 3 years, but has stopped working during the last couple of weeks. Frustrating. I get AI-generated responses when trying to get support. Unless I somehow get it fixed, I will replace it.
I just called Wyze Support - Mona C, Ticket 5284510, Log ID 2653953
No reply yet from @WyzeJasonJ … assume he is off work.
Pinging other Wyze employees to see if we can get some help.
@WyzeAndrewG @WyzeAndy @WyzeEnTing @WyzeDongsheng @WyzeJeremy
Please escalate as this is affecting many users.
Same problem here, the last update fixed the problem with adjusting the temp on the app and broke the schedules. The last to updates have caused issues
I am trying to get this issue reported to the correct people at Wyze because this is a really annoying issue to have your thermostat not following the schedule’s set temperatures.
I called and first explained everything their AI agent, who then referred me to a live agent, so I re-explained everything to the live agent, and did all their troubleshooting steps that they asked for.
The live agent seemed pretty clueless about it and seemed to be just reading a generic troubleshooting script. Eventually she said they would have to follow up with an email and I said ok, but then after I got off the phone, she just closed the ticket out as resolved! So I had to call back and re-explain everything to a second live agent.
Now I seem to have at least started an email conversation with support about this issue so hopefully they will look into this issue and fix it. It was probably a small error or oversight by the developers in the recent app update. Everything was working fine for me before this so hopefully it is not hard for them to fix this thermostat schedule issue soon.
I have the same issue. Seems to have started a day or so ago. I had a schedule that was working fine. I changed it, saving at each step. I could see that the changes were saved via the app. But the thermostat never followed the new schedule. I deleted the schedule. I created a new one. Same problem. I rebooted that device. No help.
It seems though that the thermostat is still following an older schedule. It still changes temperatures to familiar values but not the ones I have in the current schedule.
This is just maddening.
This is what mine was doing, it was following an old schedule after I had updated to a new schedule. Until I did the factory reset. Now it has no schedule which is even worse. I wish I could at least get my old schedule back but now I have nothing. Really annoying.
This exact same thing is happening to me.
I had the same schedule for years, and it’s not saving my recent adjustments to it. Built a new one from scratch and it still follows the old deleted schedule.
Tried all the power cycling, reinstalling device, logging out and back in to app, clear cache, nothing fixes it.
I had my thermostat upstairs controlling my cooling but switched it to a Nest as my wife had difficulty managing the controls. They are not super user friendly. I tried using my Wyze thermostat for heating at my main floor but needed a C wire to operate it so I moved the Wyze thermostat to the basement where I could more easily install one ($16 from Amazon to add to the line). Worked get at getting the thermostat operational but it completely ignores all temperature settings gs and schedules. I set EVERYTHING to 60 degrees but it switches itself to 65 or 67 time and again. Resetting, changing, even deleting and reinstalling did not work. I have to constantly change the target temperature back to 60, upwards of 5 times a day. I am on the verge of taking a hammer to this thing. I was once a Superfan of Wyze, now I am looking to replace every last thing except cameras. So completely disappointed.
I give up …
I’ve tried pinging Wyze Team in this topic and no response!
@WyzeJasonJ @WyzeAndrewG @WyzeAndy @WyzeEnTing @WyzeDongsheng @WyzeJeremy
Yesterday, @WyzeJasonJ replied to a topic on sprinkler schedules not working … guess that’s more important than thermostat schedules not working.
I replied directly to @WyzeJasonJ in this topic and no response!
Last night I received this response from Wyze Support on my Ticket 5284510
- We are so sorry for the wait. We are experiencing extremely high support requests and our responses are taking a bit longer than usual. An agent will be with you as soon as possible, so please hang tight.
Looks like it may be time to start replacing wyze devices. Shame
I hate to be a pessimist, but I was looking at the app page on Google Play, reading the reviews. There are quite a few recent reviews reporting this exact same issue. And every single such review, any bad review at all, really, gets a useless “Gosh we’re sorry” reply.
So this is not just an oddball issue. It seems widespread. Yet we’re not seeing a proper response.
