Wyze Thermostat Offline on Android Only
I have a wyze thermostat that shows as offline when I try to access it from my android phone. This occurs on both the beta version of the app and the non-beta version.
I can access it perfectly from my iphone and the thermostat screen does not show as offline.
What gives? I’ve tried uninstalling, reinstalling, clearing cache, clearing storage, enrolling in beta, unenrolling in beta, ripping the thermostat off the wall and reinstalling it, flipping the breaker.
No idea what to do now. I have done probably 20 logs since I’ve started getting wyze products and not one of them has been addressed and fixed yet.
Can you post screenshots of the Device Info screens on android and iphone?
Not sure what you mean device info screen? There is no device info screen in wyze app.
Select Gear Icon at top right of thermostat screen to enter settings.
Scroll to bottom of settings page.
Here you go.
Thanks for sending the pics.
Strange that the android device info is completely blank.
A couple of things to check:
  • Looks like you are running a VPN on android phone → shouldn’t make a difference but try without VPN.
  • Are you signed on to the WYZE App with the same User Id on both phones?
    Or are you using different User ID’s and sharing the thermostat?
My issue is identical… almost. My phone is a Pixel 8 pro. I have the same issue. My wife has a Pixel 8 pro and has no issue.
I can’t remember if she has a different login or just “borrowed” mine.
I did try a couple of things not mentioned.
You can not delete the device in the app. It just says try later.
I unplugged the thermostat from the wall for a few minutes. No change.
I will follow this thread for help.
The issue was my pixel was on the QPR beta and I forgot I was even on the android beta program. You can leave the android beta in september without wiping your device; I chose to wipe my phone today and leave the beta program. Everything works great now.
Does @isaacschmitz.j 's solution apply to you? Are you also on Android 16 QPR Beta?
Yes. I am on the latest qpr for 17. Beta 6 or 7. I’ll wait until I’m not on a beta and see what happens.
Today I updated to 17 qpr2 beta 3 and the issue is resolved… for now.
There’s a larger thread on this issue here: Smart Thermostat Offline - #41 by phixion35
But the gist is that the issue at this point seems to be directly related to Android 17. I believe some beta releases squeezed out the “bug” causing it, but the stable public release includes it. It’s now up to Wyze to adapt to the new changes that Android 17 incorporated to be able to resolve this since being a security compliment in Android, I don’t foresee Google changing the code or removing any security factor they implemented in A17.
