Has anyone noticed that once their Wyze spot light version 1 once triggered the light doesn’t turn back off? Like I have automation set up but I can’t set it up to only stay on for a certain period of time then turn back off. I noticed that it was turning on and not turning back off. Also does anyone know if we can use AI on it to only trigger if it’s a person?
For person-only triggering: that is what Wyze’s Cam Plus subscription adds - their official “About Cam Plus” page lists Person Detection among its detection features. For the light staying on: Wyze’s Rules documentation describes that a device trigger simply runs the action you choose, so nothing switches the spotlight off again unless you add that yourself. Wyze documents actions like “Turn on for X minutes” for their plugs, so it is worth checking whether your spotlight rule offers the same - that part is a hypothesis on my side, since Wyze only documents it for plugs, not for the spotlight kit. If it is not there, a plain schedule rule that turns the spotlight off at a set time is the fallback.
I am not sure which exact options your spotlight rule offers, so take this as a thing to check. If the Rules editor lets you add a second action after the turn on step, look for a delay or wait option followed by a turn off action for the light, which would give you the “stay on for a few minutes” behavior. If it only allows a single action, a separate schedule rule that turns the light off at a set time is a decent fallback.
Are you asking about the add-on spotlight that was made during the V3 era?
If so, those things are a bit flakey. I have a couple of them. 1 works ok … another would get stuck on. It’s not your rules, it’s the light.
All the built-in lights for the cameras that have come after, work great.
