Wyze Solar Pan Cam Recall Information details
Hey everyone, just making sure you saw the release sent out in coordination with the United States Consumer Product Safety Commission.
Wyze Labs, Inc. is voluntarily recalling certain Wyze Solar Cam Pan security cameras due to a safety issue related to incorrect installation instructions. This recall applies to Solar Cam pan security cameras purchased on or before April 3, 2026 only.
Wyze Solar Cam Pan security camera includes two different types of screws for installation: short pan-head machine screws and long flat-head wood screws. The short pan-head machine screws are intended to attach the solar panel bracket to the top of the camera. The long flat-head wood screws are intended only for mounting the product to a wall or other surface. If the long flat-head wood screws are incorrectly used to attach the solar panel bracket to the top of the camera, they may penetrate the closed-bottom brass inserts and puncture the internal lithium-ion battery’s metal casing, causing the battery to rapidly overheat, posing a risk of serious injury or property damage from a fire or burn hazard.
What do Consumers Need to Do?
Consumers should stop using the recalled Wyze Solar Cam Pan security camera immediately and determine whether your device is affected by the recall. All consumers who used the long, flat-head screw to install the solar panel on top of the camera should participate in the recall. If you are uncertain regarding the type of screw used during installation, please click on the “step-by-step” guide below to determine which screw you used in installation.
What is Wyze Offering Consumers?
Wyze is offering all affected consumers a free replacement camera with solar panel accessory or a full refund or a gift card for the original purchase price to use on Wyze’s website.
Refunds are as follows:
  • For consumers who purchased the camera through the Wyze website: Wyze will refund you at the original payment method.
  • For consumers who bought through a retailer: Wyze will reimburse you via check.
  • A gift card is available for all if you choose.
Step-by-Step Guide: How to check if Wyze Solar Cam Pan security camera is installed with the correct screws.
Please review the step-by-step guide below to determine which screws you used during installation. If you need to dismantle the camera to visually inspect the screws, you will need to download the firmware on your app. It requires that you wait 48 hours after you deplete the battery to make sure it is properly drained.
  • Click HERE to see the step-by-step guide
  • Click HERE to fill out the firmware form, so we can send your camera the firmware that will deplete the camera battery if you need to dismantle the camera.
Consumers that have not set up their camera yet.
  • Click HERE to review the corrected installation instructions before setup.
  • Click HERE to see the video.
Questions:
  • Review the FAQ below or review the press release issued in coordination with the CPSC.
  • Click HERE to review the press release
If consumers have further questions they should email recall@wyze.com, or call Wyze toll free at 888-832-7226 from 8 a.m. to 6 p.m. CT Monday through Friday for assistance.
Frequently Asked Questions
Why are you recalling the product?
The Wyze Solar Cam Pan security cameras’ incorrect assembly instructions can lead consumers to accidentally puncture the lithium-ion battery’s metal casing, causing the battery to rapidly overhead, posing a risk of serious injury or property damage from a fire and burn hazard.
Which product is affected?
The recall applies to Solar Cam Pan security cameras purchased on or before April 3, 2026, where the solar panel was attached to the top of the camera using the incorrect long flat-head wood screws instead of the short pan-head machine screws.
Will there be a refund?
Wyze is offering consumers who participate in the recall a free replacement camera with solar panel accessory, a full refund, or a gift card for the original purchase price to use on Wyze’s website. Please allow a two-three week turn around for all payment options.
  • Gift card is available for all if you choose.
How do I participate in the recall?
Once a consumer has clicked HERE to begin the recall process the following things will occur.
  • A form will be filled out to provide the information needed to verify and process the recall.
  • A specialized firmware will be sent to the participant to deplete the camera battery.
  • The recalled camera will be disabled and no longer function, even if the correct screws were used to attach the solar panel to the camera.
  • Participants will be required to dispose of the camera in accordance with local and state regulations.
  • The participant will have their choice of a full refund, store credit, or a Battery Cam Pro with solar panel attachment as a replacement.
In some circumstances, Wyze will work with a participant to send a professional deinstaller to remove the camera at no charge.
Submit a recall claim on the online form HERE
Do I need a purchase receipt? I can’t find mine.
No, you can still participate in the recall.
My Solar Cam Pan appears to be operating okay, can I continue to use it?
First, please check the step-by-step guide to determine if the screws were properly installed. Wyze Solar Cam Pan can continue to be used safely when installed correctly. If your solar panel was installed separately from the camera, or if the short pan-head machine screws were used to attach the solar panel to the camera, no action is needed.
If the long flat-head wood screws were used to attach the solar panel bracket to the top of the camera body, you should participate in the recall.
I have a Solar Cam Pan security camera. What should I do right now?
If your camera has not been assembled yet, do not continue setup until you have reviewed the corrected installation instructions found HERE
  • If your solar panel is installed separately from the camera, no action is needed.
  • If your solar panel is mounted on top of the camera using the correct short pan-head machine screws, no action is needed.
  • If you used the long flat-head wood screws to attach the solar panel to the top of the camera, you should stop using the product and participate in the recall by clicking HERE.
  • If you are unsure follow the step-by-step guide to help determine which screws were used. The guide is found HERE
Which screws should be used to attach the solar panel to the top of the camera?
Use only the short pan-head machine screws to attach the solar panel to the top of the camera.
Do not use the long flat-head wood screws to attach the solar panel to the top of the camera. Those are only used to attach to a wall or other surface.
How do I know if my camera was installed correctly?
Please go to our step-to-step guide to determine if your camera was installed correctly.
How do I dispose of my camera?
Consumers will be required to attest to disposal of the recalled camera when they register for the recall. Consumers should only dispose of the camera in accordance with local and state regulations.
Note: Do not throw this recalled camera with lithium-ion battery in the trash, the general recycling stream (e.g., street-level or curbside recycling bins), or used battery recycling boxes found at various retail and home improvement stores. Recalled lithium-ion batteries must be disposed of differently than other batteries, because they present a greater risk of fire. Your municipal household hazardous waste (HHW) collection center may accept this recalled lithium-ion battery or device for disposal. Before taking your battery or device to a HHW collection center, contact that office ahead of time and ask whether it accepts recalled lithium-ion batteries. If it does not, contact your municipality for further guidance.
How do I contact Wyze Support?
If you need help with any information regarding the voluntary recall, visit the Wyze app, the Wyze voluntary recall website Wyze Solar Cam Pan Security Camera Voluntary Recall , email recall@wyze.com, or call Wyze toll free at 888-832-7226 from 8 a.m. to 6 p.m. CT Monday through Friday.
It will be helpful if you are ready to provide:
  • Device MAC address found in the Wyze app
  • Whether your camera is online or offline
  • Whether the solar panel was mounted on top of the camera or separately
  • Which screws you believe were used
  • Whether the screws were difficult to turn or required a power tool
  • Any photos of the installation or leftover screws, if available
Where do I find my device MAC address?
In the Wyze app:
  • Open the Wyze app.
  • Select your Wyze Solar Cam Pan.
  • Go to Settings.
  • Tap Device Info.
  • Find the MAC address.
My camera is offline or disconnected. What should I do?
If your camera is offline or disconnected and you are unsure which screws were used, contact Wyze at recall@wyze.com or call Wyze toll free at 888-832-7226 from 8 a.m. to 6 p.m. CT Monday through Friday before removing or disassembling the camera. Wyze Support will provide further guidance. In some situations, professional assistance may be recommended.
Can I still install my camera?
Yes, if you follow the corrected installation instructions HERE
I already installed my camera correctly, but I need to reconnect it to Wi-Fi. What should I do?
Open the Wyze app and follow the normal Add a New Device flow.
No physical changes are needed if the camera was already installed correctly.
So just to be clear, if the camera was installed correctly and all I want to do is reconnect it to Wifi, I just need to “delete device” in the app and then start over?
Yes if installed correctly you can carry on.
I deleted it but now it wont let me connect to the app. I have a blue light but when I press setup it doesn’t do anything
Wyze has approximately 100 of my recalled Solar Cam Pan cameras, has not reimbursed me, and after months of follow-up is now telling me they will no longer assist me, while still retaining the returned units.
I posted the full timeline here: Wyze has my 100 recalled cameras, but now says it will not reimburse me
I would appreciate any help getting this escalated to the recall team.
Disclaimer: I don’t work for, speak for or represent Wyze at all, and up to the time of writing, I have not talked with any employees about your issue.
Having said that:
  1. Why did you have 155+ Solar Cam Pans (100 already returned plus 55 more waiting according to your other thread you linked to)? Were you reselling them? Using them for a commercial purpose? I have a lot of cameras (80) of different device types and even that is too many. :sweat_smile:
    Earlier this year when this was announced, you said you had just bought 10, but now you’re up to 155 after you already knew these were defective?
Why did you go from 10 to 155 and from “I’ll just keep them and use them if it gets an easy fix” (which it did…the easy fix was: “just don’t use the wrong long screw”); to “Now I want a large refund for 15.5 times the number of cameras I previously said I’d had?”
I am just trying to understand how you went from 10 to 155 when you knew there was a potential issue and then saying you’d be fine with a fix to saying you weren’t fine with it?
  1. Why were you returning the cameras instead of just disposing of them? The recall policy indicates that they would have us show proof of purchase and Device MAC address and they would just block that camera from working anymore and have you dispose of them since nobody could ever use them again.
If you retunred the cameras and they weren’t refunded my first instinct would be to assume that one of the critical conditions weren’t met in some way such as:
  • when they received the boxes they were unable to locate the cameras or the MAC address inside it (people try to do this to Amazon all the time, but Wyze actually checks).
  • Or they were unable to validate the order confirmation as the purchases all being purchased by the same person in some way.
As I said, I haven’t talked to any employees at all about it yet, but before I would try, I’d like to understand some of the above such as how and why you went from 10 to 155 units since the announcement, why they were having you return them when they were having everyone else dispose of them per the recall policy. Were all 155 for residential use? Commercial use? Resale use? Collected from people selling them online such as eBay? Ordered directly from Wyze or from Amazon or where, and when?
With good documentation and answers resolving the above, I’ll escalate your issue to an employee contact I have to see if there is just a misunderstanding of some kind. :+1:
