Can I use a Wyze motion sensor or door sensor with Phillips lights to trigger them at certain times?
You should be able to do this with Alexa Routines. You just have to set your Wyze sensors as the trigger.
https://www.amazon.com/alexa-routines/b?ie=UTF8&node=21442922011
Ok thanks but I use google assistant not alexa.
That’s ok!
You can use IFTTT to do this if you’d like.
I’m not a Google user, so I’m unsure on that. I believe that Google is still working on their automations within the home app.
You can use Google Assistant, as long as both the trigger device and the action device are recognized by your google home app, your golden.
