Wyze + IFTTT
Hi,
I got wyze sense and set it up before. Sadly I was not able to use it because I don’t know where to put it and automate stuff. But now I got an idea how to automate my yeelight, upon checking IFTT I can’t choose an option for the contact sensor and motion sensor. It says no option for the device. It seems wyze sense is not popping out on IFTT. Anyone have the same issue?
IFTTT does have sense triggers…
Did you try disconnecting Wyze service from IFTTT and then reconnecting it to IFTTT? FYI, if you can use it Alexa routines are much faster and more reliable (at last in my experience) then IFTTT.
I would agree. And easier to implement. Imo.
+1, I’m more of a Google Assistant fan, but I do like Alexa routines, much easier to use
Thank you all, I tried deleting the old setup and reinstall it. It works fine now.
Glad it’s all working. As I’m sure you are too. :star_struck:
