Some have reported getting them already!
Mine are due Monday.
My 2 sets of Sense have arrived. Showed shipped on Friday, arrived to Missouri on Saturday morning. Pretty impressed so far. Great job Wyze. Just wishing for MQTT implementation, also. But, for $20 bucks, who can complain?
Have you been on this forum before?
For $20 people complain ALOT!!
Lol, thatâs true!
Would love to be able to setup wyze sense motion detection to have an alert when there is no movement for a certain amount of time. For monitoring elderly parents. If no movement in the hall for 12 hours I would be alerted. Great products. Got mine today.
I received my Wyze Sense kit today and have installed both door sensors a the Motion sensor. Had all three setup in minutes. Very pleased .
Questions:
- When can we purchase more sensors ?
- I would like to have the ability to order specific quantity of each sensor and bridges. Possibly bulk purchase of 3 or 5 sensors in a pack.
- When will the sensors be usable in Alexa ?
Is there supposed to be adhesive on the back of the motion sensor? If so, mine is missing.
I noticed on mine that the paper backing for the adhesive was starting to peal off. Not sure I will use that or go with the 3M Command type stick-ons. Once I decide on itâs final installation point, I guess that will make my decision for me.
Iâm thinking of using velcro dots that are on double stick tape themselves. Iâve got some ânight lightâ or âcloset lightâ type fixtures that use 2 AA batteries. They rundown and require replacement every several months. The velcro makes it simple to move them around.
Is there a way to delete the history of Sense Open/Close? I have being doing a lot of testing, and would like to reset it to start a clean history.
Hello @Tronzie, no there isnât an option to do this like you can with the cameras.
So far I have not been able to get any of my wyze sense devices to connect. I also have one of the sensors that flashes 5 times fast when I reset it. I have tried removing the batteries from all of them but I can never get them to connect to the bridge. Also, There is no adhesive on the back of the motion sensor. I am not sure if that is supposed to be that way or mine is missing it.
Here are the Wyze Sense troubleshooting guides:
https://support.wyzecam.com/hc/en-us/articles/360025999952-Wyze-Sense-Troubleshooting-Guide
If that doesnât solve it, keep in mind that this is primarily a user-to-user forum. If you donât get help here from the community, file a support request including log files. That will ensure that the logs are captured. You might want to submit the ticket right away because thereâs somewhat of a backlog. You can always let them know itâs already resolved when they contact you.
I had issues with the 5 flashes and not pairing to the hub. I had to move the sensor close to the camera and complete the pairing process. Once paired, I could install the sensor in the original location and all seem well.
My motion sensor doesnât blink lights while pressing the reset button on. And I am not able pair. Anyone else facing the same issue?
I use Command adhesive strips with mine so they can be easily removed, if necessary, and donât leave an adhesive residue behind. Iâve also used them to mount the Wyze Cam metal circles for mounting the cameras.
The cameras have a 5 min cool down period after they are triggered before they send you a notification, or can record a 12 sec clip again. With the sensors you get a notification and recording every time it is triggered even if its within less than 5 minutes.
Might be dead on arrival (defective). Mine was. First check the battery insideâmight be dead. If it doesnât work with a fresh 3V battery, contact WYZE support and (after they get back to you in a week) they will send you a warranty replacement.
I like the command adhesive ideaâŚ!![]()
Iâve recently purchased half a dozen cameras and sensors. Iâm still in the process of mounting them all but hereâs what Iâve learned from trial and error:
The sensors can trigger one or more cameras to record. The cameras donât have to physically have the bridge in it to be able to record. But one camera does need to have the bridge for it to be online and it must be properly connected (solid blue light).
A bridge will not (at least for me) work if youâre piggy backing the camera from another camera. I.e. The camera needs to be plugged to a direct power source, not another camera.
These cameras support micro sd cards of at least 128GB. So far I have 5 cameras all running 128gb cards perfectly. I estimate that theyâll hold 2 full weeks of continuous HD recording before overwriting. I donât expect issues putting a card in my 6th camera.
The notifications often start late or stop short for us but since we record 24/7, I can simply go back and view whatever feed the notification didnât send if itâs something that interests me.
Iâm not fond of the motion sensor. I canât get it to stay online. Iâm also having issues with night vision. It doesnât seem to work that well.
All-in-all I have about $50-60 invested per camera (camera, micro sd, waterproof case, and longer cord) and Iâm very happy with the ROI so far. Theyâre much better than the Reolink cameras I originally bought (that wouldnât connect to the Internet because of my network DNS settings). I just invested another ~$100 on smart switches and flood lights that I plan to run this weekend. Once itâs said and done, I should be able to set up the flood lights to come on at dusk and off at dawn, which should take care of my issue with night vision. And Iâll have a pretty secure home for much much less than other camera systems and I wonât have to pay a monthly fee to access my videos.
