Wyze sense causing cameras to go offline
Installed Wyze sense a month ago and ever since, my two cameras alternate going offline almost daily. I unplug the one that is offline and plug it back in, then the next day, the other one goes offline. A few days ago, I uninstalled the sense bridge and the cameras have been perfect ever since.
Same happens to my V2 camera with the Bridge plugged in. It stops responding to the Wyze app about twice a day. It never went offline like this before, it started when I added the Sense Bridge. It’s not the camera because if I remove the Bridge, it doesn’t happen.
Also, if I take the bridge and plug it into the other camera, then that camera starts doing the behavior, so it definitely has to do with the Bridge.
A power cycle fixes the issue. No idea why.
And I believe the sensors connected to it continue to work, just the camera goes where the Wyze app can’t connect to it.
Thanks for the response. I have tried power cycling and seems to fix the issue for a day and then back to the issue the next.
