Wyze sd card cover
Hello
The cover to protect the SD cover came off. Is there a trick to pop it back in?
I have had other devices using this type of retainer. I tried shoving it into the hole, and ended up damaging it. The cam will have to be partially disassembled so the piece can be pulled through the back side.
Here is a tear down video on YouTube. There are plenty more.
Make sure the SD card is removed before disassembly. :roll_eyes:
I had great luck removing the rubber screw plugs using a dental pick.
