For nearly a week, my Wyze Scale X has stopped syncing to the Fitbit app. I have measured my weight every day, but the last measurement that appears in the Fitbit app was from Monday, May 19. I’ve tried removing and re-adding the sync authorization but it has made no difference. Is there something going on with the syncing between the two platforms?
I’ve been having the exact same issue. Last reading in Fitbit was May 19th.
I tried unsyncing and resyncing both apps and nothing.
Pixel 8 pro fully updated.
Same issue, and same troubleshooting steps. Last time a weight synced to Fitbit was the 19th. Bump! Not that it is relevant because I’m sure all of this is happening server side, but Pixel 9.
From what I’ve seen on the Fitbit subreddit and elsewhere, multiple different brands of scales all stopped syncing with Fitbit on May 19. It seems something might have changed on the Fitbit side, but a rep from one of the brands posted that they’re releasing their own app update to fix the sync issues. If that’s the case, hopefully Wyze is aware of it and working on their own fix too.
exactly same issue, same dates Pixel 9 pro xl
Has this been resolved? I’m having the same issue…
It’s been working for me since a few days after this started. Worked OK this morning.
