Will the Wyze Scale work with the beta version of the Wyze app. I am using version 10.3 and when I try to add the scale I get an error that says “This device isn’t supported “.
Yes! I’m using the Beta app 2.10.32 and the scale is working fine.
Okay, didn’t realize that there was an update to the IOS beta app. Updated it and added the Wyze Scale, thank you!
Regards,
Don Townsend
You’re welcome!
