1). Where do I find battery status on Wyze Scale? How do I check current battery strength?
2). Only weight is showing up on scale and app for some reason. Where have the other stats gone?
Hello @cgclark1331
The Wyze app does not show a battery status for the Wyze Scale or Battery Strength.
Low Battery and Critically Low Battery messages will be displayed on screen on the Scale
At your last reading were you bare footed? If you have shoes and/or socks on the scale will only present weight.
Did you enable the Weight only feature?
Hope this helps!
