Wyze Pro LED Strip and 90 degree connectors
Just got my Wyze Pro LED Strip. I need to install a tight 90 degree turn. Has any one tried something like this?
Thanks,
Jim
I have been involved in music synchronized Christmas shows for about a decade. Similar strips have been used for many years. Pretty much NO ONE has found ANY of the clamp on solderless connection similar to the ones you posted to be worth anything except trashcan bait. Don’t waste your money.
Far better to solder small jumper wire around the corner.
Can’t you do a loose 90-degree loop?
Thanks for the replies. The installation is under a lip of my bar and a loose 90-degree loop would show. I’m actually thinking of using an aluminum channel for the strip.
