Wyze portal not displaying cams in Safari V 18.2 on Mac running Ventura 13.7.2. It was working until recently…nothing changed on it.
It is displaying in Safari V 17.6 on Mac running Monterey 12.7.6.
Welcome to the forum @jaaprime
Have you tried clearing the browser cache on the affected browser?
Like everything - cookies? history? or just the cache
Just cache.
Yeah…that didn’t work.
Tapping some Apple users shoulders for some other ideas.
It’s odd that it works on one mac but not another. It’s also not working in Chrome.
I’m suspecting something to do with Private Relay, although I have mine on and works fine on both Sequoia and Monterey. Are you on WiFi or Ethernet? If you have them both try disabling one then the other and see if that helps. Also play around with Private IP address, turn it on and off and see if it makes any difference.
Hey…so i turned private relay off and boom it worked. I don’t recall changing that.
Any way around this…I like hiding IP.
As far as I know Private Relay only affects Safari, you can turn it back on and use Chrome for Wyze Web View and do all other surfing using Safari. Your web surfing will still be protected. What I find interesting is that I have it on and it doesn’t affect my Safari or Chrome. You might want to try and have the IP location set to “Maintain general location”, that way it will not assign some weird IP address that might throw of Wyze Web View.
If you did any OS update lately, the update might have turned it on.
EDIT: One more thing. Go to your Firewall settings and allow incoming connections for Wyze.
