Wyze plugs showing off even though they are on
iPhone 14 Pro Max Wyze app 3306.
Starting about 2 hours ago - that I know of - if I turn on plugs to run lights or fans they will show on then off in app but they are running. I turn them on again in app and they will turn themselves off again in the app but the devices hooked to them are still running and the timers are still running.
Or turning one on again will shut off a different plug that was running. Very confusing. This is a new problem. Have been running same internet and number of cams and plugs for months. If I select one to look at for timer it will shut another one off but only in the app. The devices stay running.
Have rebooted iphone and cleared cache. Internet is up and running.
Did you close and reopen the Wyze app? Not log out, just close and reopen. This step usually corrects these missteps in smart devices status.
