Wyze Plug Now Available!
I don’t see it as an assignment, I like testing things and it helps me to know various issues, so I have no problems testing it
Yes, I have completely turned my router off, pulled plug out of the outlet to simulate loss of power. After up to an hour, the plugs come back on in the same state as I had them in. This is exactly what I was hoping for and very happy with my plugs. I have tested this several times and I get the same results.
Very cool. My curiosity might have me testing the brand x plugs and the Wyze plugs (when I get them), but not up at the cabin for a week or so. Stay tuned!!
I unplugged one a couple of times and it stayed in the off opposition as it was
It doesn’t seem to be live on amazon yet. Did amazon give you a link to the listing? So we can keep an eye on the page and order as soon as it’s live. :smiley:
Plugs are not in stock on Amazon yet.
https://www.amazon.com/gp/product/B07XZT24B8/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Yep, looks like it is going to be 3 or 4 weeks maybe longer.
Just popping by to acknowledge that I read everything here but our awesome Mavens seem to have everything well in hand. :slight_smile:
Thank you, Mavens!
Does anyone know if the plugs can be included in an Amazon Alexa Routine?
Yep , they sure can , I have some in a Routine
Does anyone know if there is a way to integrate then into Hassio?
I don’t think Wyze has been working on any integration directly, but it looks like some people have put together some solutions over there. Wyze sense sensor integrations - #23 by tube0013 - Feature Requests - Home Assistant Community
Edit: Sorry, I guess you were asking about the plug specifically. That thread shows how some people have put together some solutions for Wyze products in general. So maybe it’s possible. Since it’s not something offiicially integrated by Wyze, I’m guessing you’d probably have more luck asking about it in the home-assistant community, though.
If use the sensor integration and it works fairly well. For now, I am going to stick to Sonoff device for HA.
