I have a wyze plug that doesn’t fully turn off. It has low voltage leak. I haven’t had a chance to meter it. When I was running Christmas lights the lights would still slightly glow after Turing the plug off. Has anyone else had this problem.
I have not had this issue or seen reports of it elsewhere, I would recommend you open a support ticket for this issue
Interesting. I haven’t heard of that. Do you have another Wyze Plug, too? Can you determine whether the Christmas lights have the same behavior with the other one?
do you by chance have other plugs that show this behavior too? or could try the same lights with a different plug but in the same outlet to fully determine its the plug?
Are the lights led. Sometimes led lights won’t shut completely off with smart triggers. I’d also try any other light source and those lights in a different wyze plug. Trouble shoot the heck out of it. I actually find it quite fun finding the solution
Has there been any additional confirmation of voltage leak on the load side?
I have a few other plugs that doe this and some that do not.
Did you take a meter and check it? What kind of readings are you seeing?
No, I don’t have a Wyze plug to test. Which is why I asked here. Did you check it with a meter?
