Wyze Plug: How to overrule daily schedules for a few days
I have Wyze Plug controlling a recirculating pump on a daily schedule and it works great. But I want the ability to turn it off by iPhone and stay off until I turn it back on a few days later by iPhone, and have it resume its normal schedule. Is there a rule that will do that?
You wrote a schedule correct? If you did at the top there is an enable slider. You could just slide that enable slider off for the few days. And then when you want it to go back to work just slide that back to enable and it should go right back to your schedule.
I just wrote a generic schedule so that you can see what I’m talking about.
Thanks. Looks reasonable I think it will work for my purposes.
Glad to help.
