On the Wyze Plug page it says “Wyze Plug also “remembers” its last status so if you turn the switch off the Plug will return to its previous state when power is restored”
Is there a way to make the Wyze Plug change it’s status to ON whenever power is restored? If the Wyze Bulb is in the OFF state, turning the connected light switch off and on, will turn the Wyze Bulb to ON state. I’d like the same functionality for the Wyze Plug. In my case the Plug is behind furniture, so it’s not easy to push the button on the Plug. My wife doesn’t want to use the app or plug button to change state from OFF to ON, just the light switch. If this could be a software option, that would be great!
