I just set up a TP Link Deco S4 mesh wifi system and I cannot get my V3’s to stay connected. Wifi name and password are both the same. They initially connect, as I get a notification on my phone when they are initially set up, but then I get offline notices when I try to access to cameras from the Android app. I had no issues previously on my standard TP Link router, and I have gone as far as to change the whole mesh network to 2.4ghz only. The only camera that worked without any issue at all is my floodlight camera. That thing didn’t care in the slightest, lol. All 5 of my V3 Pans are out of commission right now, and they are anywhere from 6 feet to 20 feet from an access point, so we shouldn’t be dealing with any signal issues. I’m a career tech support specialist, so setting this up is right in my wheelhouse, but I’m at a loss. I’m open to any and all suggestions.
As another note, I deleted the camera and started over on one. When I set the camera up, everything fine. I scan the QR code, it accepts it, sends me a notification that it recognized movement on the camera (me), and then it just won’t connect. When I check the router and see my connected devices, they show connected on the 2.4ghz band but there is no data coming through them, but they do show up in the router.
I checked other threads and the last one I found is 21 days old. It mentioned a security issue with the cameras that may be causing this. Is there any movement on that possibility? Thanks!
Edit:
I found that I have a single camera (V3 Pan) that is working. It is on 4.50.4.7252. It is closest to the “main” router. Most of my cameras are on the same firmware and are not connecting. Perhaps it has something to do with them trying to connect ot that main device and not the satellites?
