I am facing the same issue. I have 2 Pan v3.
One doesnt get stuck on the fan and is working perfectly, where as the second one which has the same settings as the first one whenever it moves due to motion it gets fixated on the Fan.
Any solution?
Fyi: the firmware is up to date
Using cardboard I made a sort of hood that sits above the camera. If the camera tries to look up the view of the ceiling fan is blocked, so it doesn’t stare at the rotating fan. Not an elegant solution, but it works, and I don’t really need to detect motion up toward the ceiling anyway.
How did this work for you?
