Wyze Pan doesn't record event
Hello, I have 2 Wyze Cam and 1 Wyze Pan. I have enabled event/sound recording for all 3 of them. For the 2 Wyze Cam, the event recording happens as expected. Anytime, someone or some sound happen, it will be recorded.
But for Wyze Pan, it is not reliable. Only 10% of time, the motion will trigger the recording. 90% of the time, there is no event.
I am wondering is it because the sensor difference of Cam and Pan?
Thx,
David
Have you updated the firmware recently?
Edit forgot to add what @omstzo said!
Check this other thread 4.10.6.156 Update Pan Cam Problems
