Just received a new Wyze pan cam. Setup went fine and firmware was updated. All seems to work (live stream, pan, etc.) except no events (like motion) are detected, no notifications are generated, and nothing is being recorded to the cloud. Have read all the faq but no help. Cannot flash a prior firmware since I don’t have a SD card. Any ideas to fix this would be great, or is this a known firmware issue?
I’m having the same issue as well. It detects sound but only when its super loud noises but I haven’t had any motion detection recordings and I have the settings max’d to high. I’m hoping it gets fixed with an update.
When you click each of these, it should download a file ending in .zip to your computer (you need to be on a computer to do this).
Expand the compressed .zip file. This is usually done by double clicking it. On some computers, it will expand automatically. The result will be a file called “demo.bin”. If that’s not the exact hame it gets (eg, sometimes it ends up demo.bin.bin), then rename it to “demo.bin”.
Insert your microSD card into the computer. Copy the demo.bin file over to the top level of the SD card directory. Make sure it’s the only file/folder there. Delete any others.
