Just got my Wyze Outdoor Camera and had a simple question…
Are the included screws rust-resistent? Are they stainless steel or galvanized zinc?
They are not. Mine are rusted and I’m trying to find the proper size so I can buy replacements.
Mine are stainless steel and have been outside for a year, no rust. Go to the hardware store and get a #5 or #6 stainless steel screw 15/16 inch long. A #5 will fit in the slot to slide the cam on to, a #6 will fit through the hole for the base directly. Take the base with you to check the fit.
