Is it possible to put in this feature? right now the max is 30 days, is it possible to have it without a duration? I feel this should be an option for us. I got solar panels with the WOC as well so that should help with less charging for me.
This is not available right now, you have to set a duration.
You can use the #wishlist to suggest this though.
Thank you, hopefully they can fix it and make it a reality. Or at least give us the option for motion based recording with no cooldown time and record to the sd cars like the wired wyze cams.
