Wyze Mesh Router with Bark Home
Has anyone tried setting up the Wyze Mesh Routers with Bark Home? Are these routers compatible? Thanks in advance.
No, but I just got rid of mine. They haven’t been updated in 4 years. I would ditch them for safety sake.
I can say I never had any compatibility issues with various IoT devices using the Wyze Router.
I am guessing that the routers are no longer supported?
Supported isn’t a word I would use. They will allow you to buy and add the device to the app. But that’s it.
No security or feature updates. Which I consider to be unsupported because routers need security updates constantly.
