I will be getting the Wyze mesh router soon to replace a mixed wifi setup (separate ssid for the 2.4 and 5 ghz bands). My plan is to go with one ssid for all bands. Will have 4 Wyze mesh routers.
Can use some help with the following questions.
When setting up the 2.4 ghz side is it best to assign each router the same channel, or to use different channels to reduce interference?
Is it possible to assign the 6 ghz as the backhaul? Three of the routers should be wired backhaul (will use home wiring with a switch, removing the wiring from the internet) but one location will not have wired backhaul capability. If I can use 6 ghz as the backhaul would it be recommended to have the 5 ghz routers on separate channels?
Sorry if these questions are automatically done in the app. Just want to make sure my installation plan goes well.
