Wyze Mesh Router Local UI
HI. I have the Wyze Mesh Router WI-FI 6 AX3000. I’m trying to access the router local UI and it wants a username and password. It says it is on the label at the bottom of the router, unfortunately its not. Customer Service told me to reset it, which I did, but I still don’t have a username and password to enter. Anyone know if there is a default username and password like admin / admin?
Thanks
No default user name/password other than those printed on the label.
Google AI suggests this:
Credentials Missing or Forgotten: If you cannot find the credentials or need to reset them, open the Wyze app on your phone, select your router, tap the gear icon, go to Advanced Settings, and select Reset Mesh Local UI Login.
Hard to spot on the FCC LABEL:
The problem is there is nothing printed on the label
Can you post a photo?
