How much space do i need next to my deadbolt to install the lock?
Do lots of people just put the keypad on the door itself if there is roof stucco next to the door?
@vkeisler
The lock is 2.5 inches wide so you would need 1.25 inches each side of the center of the deadbolt
Thanks. That should work. Can someone post a photo of the side that mounts (the side that is not seen after installed) so I see how wide the edges are. Look at the photo I posted and see if you think it will fit on top of my deadbolt. There’s a small amount of room between the deadbolt and the window on my back door
