Our deadbolt is under the door handle (instead of the common practise of above) so I’d like to know if the Wyze lock can be installed upside down so it won’t hit the door handle above?
Thanks!
Thanks!
I don’t see why not.
Worst case scenario, Wyze has a good 30-day return policy, so you could always get it and try, and if it doesn’t fit your needs, then you could return it.
My main question is whether the fingerprint reader can still stay right side up, or if it would have to mount upside-down in order to fit the design correctly. I do not know the answer to that without looking at it more closely.
If you do try it, you should come back and post about it either way. ![]()
