Is there any way to increase the amount of force that the Wyze lock exerts to unlock? Mine is hit and miss, sometimes stopping just short of fully unlocking (the lock itself thinks it unlocked, but the deadbolt is still slightly out – preventing you from opening the door). It locks just fine, but doesn’t always unlock. I’ve checked the lock’s action and while there’s a bit of friction, it shouldn’t be enough to prevent the lock from unlocking all the way. I’ve lubricated the lock and adjusted the base plate to no avail. When I manually complete the unlocking process, it’s just a small movement and very little effort to turn. Suggestions?
Related topics
| Topic | Replies | Views | Activity | |
| Wyze lock jam | 1 | 1110 | February 29, 2020 | |
| Wyze Lock Manual Range of Motion Lacking | 6 | 1245 | April 5, 2020 | |
| Wyze lock - manual locking problems | 61 | 7115 | September 29, 2024 | |
| Wyze Lock Bolt | 0 | 452 | September 30, 2022 | |
| Wyze Lock possible bad batches | 16 | 1631 | March 21, 2020 |
