I would like to know how to install my Wyze lock on deadlatch. I just moved to a new place with only deadlatch.
Any help would be appreciated.
@CGross Welcome to the Wyze forums! Unfortunately, the deadlatch will not work with the Wyze Lock. You will need to install a standard single cylinder deadbolt on your door. See links below.
https://www.amazon.com/dp/B07J5MNSVT/ref=cm_sw_em_r_mt_dp_ZVY8MA9878TGCKCGBA93?_encoding=UTF8&psc=1
thanks so much for your quick response.
If I may suggest to take a look at the “Lockpicking Lawyer” YouTube channel for a lot of good and poor locks.
